cli different characters/symbols which is not readable.
  • Problem
  • Updated 10 months ago
  • Not a Problem
Kindly help.Thanks
Photo of Resolut1on
Resolut1on
  • 704 Points 500 badge 2x thumb
Posted 10 months ago
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,268 Points 3k badge 2x thumb
Gerald,
Can you please clarify your question in detail? sharing some snippets or error message which you are getting in the cli
Regards,
Sumeesh
Photo of Resolut1on
Resolut1on
This is a switch xos, I will give you details and screenshots once I check it again maybe on Monday. I will just keep you posted. thanks for support
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,266 Points 3k badge 2x thumb
Check to make sure the serial settings are correct in your terminal emulator
Gerald,
As stated by my colleague (Brad) check for the serial settings.
Hope this KB Article might help you
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-console-into-Extreme-and-Enterasys-...
Regards,
Sumeesh
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Like Brad said, I'd check the serial settings. It sounds like the baud rate may not be correct.
