Client Isolation - Extreme Wireless controller
  • Question
  • Updated 2 years ago
  • Answered
Hi Team,
Does anybody have any ideas of how client isolation can be achieved for users on the same SSID and in the same vlan in Controller. I know other manufacturers have a simple Client isolation feature that will achieve this but I can't find it in Extreme Controller.
My ultimate goal is "Users have to communicate only gateway not others".
Any ideas welcome..!!!
Photo of Boopathy Chandrasekar
Posted 2 years ago
Photo of Nathiya Munuswamy
Nathiya Munuswamy, Employee
  • 1,706 Points 1k badge 2x thumb
Hi Boopathy,
Please find the steps below to block wireless client to client traffic on a WLAN.
  1. From the Controller/Appliance GUI
  2. Select WLAN Menu
  3.  Select desired WLAN to block MU to MU traffic
  4.  Click Advanced button
  5.  Check the box in the CLient Behavior Window  Block MU to MU traffic (not supported on Bridged at AP topologies)
  6. Click the Apply Button
  7.  Click Save Button
Reference article below,
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-block-wireless-client-to-client-tra...
Regards,
Nathiya M
Thank you for the quick response and I will confirm soon..!!
Hi Boopathy,
Please confirm, is it B@EWC or B@AP topology?
Regards,
Nathiya M
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,078 Points 5k badge 2x thumb
In the B@AP the "block MU to MU" does not work. You can create rule in Policy Role and allow only traffic destined to your gateway MAC and Broadcasts all other can be blocked.
Please check the policy rule configuration for B@AP setup,
https://gtacknowledge.extremenetworks.com/articles/Solution/Block-MU-to-MU-enabled-but-users-can-sti...
Regards,
Nathiya M
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,280 Points 2k badge 2x thumb
MU to MU also doesn't work if the client are connected on the same AP.
Photo of Craig Guilmette
Craig Guilmette, Employee
  • 2,510 Points 2k badge 2x thumb
