client machines are not connecting particular SSID
  • Problem
  • Updated 11 months ago
  • Solved
  • (Edited)
Getting entrasys related pop up message while connecting Wifi SSID in client machines and unable to connect SSID
please refer the error messages in end client machine while connecting Wifi SSID
This is the Net sight Log while connecting particular client
Photo of vidya sagar
vidya sagar
  • 120 Points 100 badge 2x thumb
Posted 12 months ago
Photo of Evan Kuckelheim
Evan Kuckelheim
  • 658 Points 500 badge 2x thumb
Are you using a self signed cert? Looks like it is. You need to use a signed cert. If this is 802.1x there is an option to verify the server's identify by validating the certificate. You can turn it off to remove this error. Although you should be using a real cert.
Evan Kuckelheim
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
Vidya,
Are you all set with your issue? Did what Evan provided resolve your issue?
