CMOS Battery
  • Question
  • Updated 11 months ago
  • Answered
Can someone confirm the link below please... I want to know what type of internal battery the Summit x150 24p uses if it the one on in the link below.
Link to Amazon
Photo of YouBoy Kumar
YouBoy Kumar
  • 174 Points 100 badge 2x thumb
Posted 11 months ago
Photo of Drew C.
Drew C., Community Manager
  • 36,182 Points 20k badge 2x thumb
I can't comment on this specifically, aside from asking that you consider an RMA. If that isn't an option for you, then your next best bet will be to open the switch and check it on your own.
Be sure to familiarize yourself with how to properly remove the battery if you go this route, so you don't damage the board.
