Code recommendations for X450G2
  • 2
  • Question
  • Updated 1 year ago
  • Answered
I am looking for a conservative code upgrade recommendation.
We have just under 100 X450G2 stacks deployed on a customers network. Per the software release recommendations page (Updated in March) we are running 21.1.3.7-patch1-4.
We have experiences a know bug on this code twice now. When replacing a failed master the ssh key gets corrupted causing the replacement switch to fail repeatedly.
The tac  engineer I was working with recommended 22.3.1.4, but that seems like a step. It is a different major release and does not even have any patches yet. I cannot find the CR he reference but here are the log messages.
10/02/2017 10:02:38.34 <Crit:Kern.Card.Alert> Slot-1: 55561c44  8fc40000 lw     a0,0(s8)
10/02/2017 10:02:38.34 <Crit:Kern.Card.Alert> Slot-1: 55561c40  00000000 nop
10/02/2017 10:02:38.34 <Crit:Kern.Card.Alert> Slot-1: 55561c3c  0320f809 jalr   t9
10/02/2017 10:02:38.34 <Crit:Kern.Card.Alert> Slot-1: 55561c38  8f9990a4 lw     t9,-28508(gp)
10/02/2017 10:02:38.34 <Crit:Kern.Card.Alert> Slot-1: 55561c34  1091000f beq    a0,s1,0x55561c74
10/02/2017 10:02:38.34 <Crit:Kern.Card.Alert> Slot-1: 55561c30 <8c440000>lw     a0,0(v0)
10/02/2017 10:02:38.34 <Crit:Kern.Card.Alert> Slot-1: 55561c2c  00561021 addu   v0,v0,s6
10/02/2017 10:02:38.34 <Crit:Kern.Card.Alert> Slot-1: 55561c28  0017b080 sll    s6,s7,0x2
10/02/2017 10:02:38.34 <Crit:Kern.Card.Alert> Slot-1: 55561c24  8e020000 lw     v0,0(s0)
10/02/2017 10:02:37.86 <Crit:Kern.Card.Alert> Slot-1: Code:
10/02/2017 10:02:37.86 <Crit:Kern.Card.Alert> Slot-1: Process exsshd pid 2119 died with signal 11
We do not want the customer to have to deal with the ssh key bug but we also don't want to open ourselves up to potential new issues by moving to to new of a code version.
Thanks for your thoughts,
Photo of David Coglianese
David Coglianese, Embassador
  • 7,128 Points 5k badge 2x thumb
Posted 1 year ago
  • 2
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Hello David,
The easiest way around this issue it to re-create the SSH key on the stack. Here is an article that explains this a little better and has the CR:
https://gtacknowledge.extremenetworks.com/articles/Solution/Why-does-Enter-passphrase-show-up-during-boot
Patrick,
Thanks, that is the same article the other engineer found.
The work around is a bit of a rough as of the customer who will usually be looking to get back up and running fast. Both times I encountered this I saved the config as a script, unconfigured the stack, ran easy stacking, loaded the script, enabled ssh. It works but takes a few minutes.
So my only real alternative would be the last patched version of 22.2.x? That should have a little more run time and be fully patched by now.
Unless you advise against it I will likely go the 22.2.x route?
Thanks,
Patrick Voss, Alum
Hello David,
With any upgrade of code I would recommend looking at the release notes for that version to make sure there isn't any potential issues with the configuration running on the switch.
The solution 2 workaround should prevent the issue form happening at all and prevent any downtime as long as it is done before any SSH attempts are made. I recently had a case where the customer did this and they did not experience any crash.
Hope this helps!
Yes, I will check the release notes for the latest version of 22.2.x and see how that looks.
Solution 2 did not work for us the first time we encountered this. The second time, i went strait to the nuclear option.
Thanks for your input. I will check the release notes and post if i have any concerns.
Photo of George Smith
George Smith, Employee
  • 110 Points 100 badge 2x thumb
Dave,
Please let me know if this link works for you.
Click Here For Extreme Networks Software/Hardware Compatability Matrix
All the best,
George
George,
I am aware of the Matrix that is what led me to the bugged code in the first place. We should probably update that more often than every 7 months.
