Combination ports on Extreme X480-48t
  • Question
  • Updated 4 years ago
  • Answered
Hello experts,
I am working now on a project that involves a switch extreme X480-48t, my question is about combination ports, this switch have 4 combination ports, i need to use the optical ports as a regular port, I mean, I need to add the port to a virtual router working with VRRP, it is possible?.
Thanks in advance for your help!.
Photo of Miguel
Miguel
  • 142 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Official Response
Hey Miguel
the combo ports share a phy so the cooper port and fiber port with the same port number cant be used  at the same time.  you can use either the cooper or fiber port.  If a switch has 4 combo ports where 4 of them are cooper and 4 of them are fiber you can use any 4 of the 8 in any combination.
You don't disable the port the switch will sense which port you are using and make the other one not useable.
Does that help?
P
