command for local packet capture on x460 v16
  • Question
  • Updated 2 years ago
  • Answered
Photo of Kaon Thana
Kaon Thana
  • 256 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,040 Points 5k badge 2x thumb
It does.  But the command is hidden and you can't tab through it.
Photo of Kaon Thana
Kaon Thana
I see thanks. I tried this:
debug packet capture ports 48 on print-to-console
And got no result. How can I view the packets on a specific port?
debug packet capture ports 48 on print-to-console  Make sure your on console.
This is better.  "debug packet capture ports 48 on count 100 file-name pcap_capture"
It captures 100 packets and places them in a .pcap file called pcap_capture.pcap  in /usr/local/tmp on the switch.
ls /usr/local/tmp
Photo of Kaon Thana
Kaon Thana
Thanks! Is there a built in command to view the file without using TFTP to upload it somewhere?
'cat' doesn't work
Photo of Edward Tsui
Edward Tsui, Employee
  • 602 Points 500 badge 2x thumb
As far as I know, there is no built-in tool to view the content, all you need is to TFTP it to somewhere and open with wireshark
You have to upload it to a TFTP server. If you have Console access you can use my first command. It will display the packets to the console.
Photo of David Coglianese
David Coglianese, Embassador
  • 7,208 Points 5k badge 2x thumb
I am not sure what started the debate around our office, but I am hoping someone can clear it up.
Does this packet capture method capture all traffic or just traffic that hits the cpu? I see that ingress and egress have to be captured separately, but will we see all ingress or egress traffic?
Thanks,
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,720 Points 10k badge 2x thumb
Hi David,
that is a good question, I do not know the answer either. If I remember correctly, older EXOS versions (15.1, 15.3) allowed capture of traffic hitting the CPU only. The interface name used for this contained "bcm", I think.
The GTAC Knowledge article mentioned above pertains to EXOS 15.4 and later and uses EXOS front-port names.
Looking forward to an authoritative answer. :-)
Erik
BTW there is an article to capture management port traffic as well: How do i take a packet capture of the management port?
I was told when you start capturing on a port with "debug packet" an internal ACL is created to kick the port traffic to CPU, and it's captured from the CPU.
Photo of Kaon Thana
Kaon Thana
When I ran the above "debug packet capture" command I was not able to see traffic like pings/udp going through the port. I only saw this traffic after I enabled a port mirror to another server on the switch.
