Compatibility between EAPS and G.8032 ERPS
  • Question
  • Updated 4 years ago
hi Experts,
Can EAPS interoperable with G.8032 ERPS?
http://extrcdn.extremenetworks.com/wp-content/uploads/2014/04/Layer_2_Protocols.pdf
From P.68, it mentions:
• Basic interoperability with EAPS with G.8032 acting as an access ring. Flush notifications will be sent Link monitoring using CFM or native local link monitoring methods.
it shows that it is interoperable, just wanna know more detail on that.
if a network running EAPS and there is some old device with G.8032, just wanna know if that old gear can interoperable with the EAPS. thx.
Ken
Photo of Ken Johnathan
Ken Johnathan
  • 130 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Ken
the two can interoperate if one is a sub-ring of the other.  They will send will send flush notifications.  You cannot create one ring with some nodes using EAPS and others using ERPS/G.8032.
Does that help?
P
Ken Johnathan
Hi P,
Thanks for the prompt reply.
as i just planning for a migration from EAPS to ERPS as below, the new core supports ERPS only.
step 1: connect the new core as ERPs to the existing EAPS core:
Step 2: migrate TOR with 1 uplink to new core  (erps) and 1 uplink still connecting to existing core. (eaps)
is it possible? Or i need to configure the ERPS on the existing TOR and Core too? thx.
Actually, i just wanna achieve a migration without down time. thx.
Ken
Ken Johnathan
hi P,
i think it is feasible if ERPs can be a sub-ring of EAPs as below:
Step 1: Remove 1 uplink from TOR
Step 2: Disable EAPs on TOR (as no longer a loop at that moment
Step 3:
I think it is doable. Pls comment. thx.
The new core is X8 but we wanna replace EAPs with ERPs through this exercise. thx.
Br,
Ken
Ken Johnathan
Hi Paul,
do u have comment on that? thx.
Br,
Ken
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
If its a datacenter that too with  BDx8.
why cant we migrate to  MLAG.
Reliable for datacenter.
15.3.1.4 --Latest patch is the most stable for MLag.
We can have active/active for VRRP .
I am not saying EAPS or ERPS is bad but MLAG in datacenter is really the best
Photo of Paul Russo
Paul Russo, Alum
Hello Ken. Apologize for the delay I have been traveling. I believe your design will work. I also think that MA as mentioned by Parthiban would be a bettwe design. It provides redundancy like EAPS without the blocking
P
