Compatibility Matrix for Firmware
  • Question
  • Updated 1 year ago
  • Answered
Hi, I am looking for the compatibility Matrix of Firmware for the A2 Series & S4 Series. Anyone can share the path from where I shall get it?
Photo of Makeshbabu
Makeshbabu
  • 90 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,058 Points 5k badge 2x thumb
(Edited)
Photo of Makeshbabu
Makeshbabu
Actually we are planning to replace the top level switch from N3 to S4. So after replacement, The Scenario is Top Level is S4 Series & Lower level is A2. So we need the compatibility matrix (comparison) between S4 & A2. Is there any link to find such combination?
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,792 Points 10k badge 2x thumb
for the S-Series, take a look at Software Release Recommendations. For the A-Series, a post in the thread Extreme Hardware/Software Compatibility and Recommendation Matrices tells us that the latest released version is recommended:
Following up: I've verified that for the A/B/C/D/I and G series products, the latest version of the SecureStack software is always the recommended version.
[Both articles are linked to from the GTAC Knowledge article What is the recommended software version for my platform?]
For the S-Series you should take a look at the GTAC Knowledge article Explanation of S-Series Firmware Tracks as well.
Thanks,
Erik
Photo of Makeshbabu
Makeshbabu
(Edited)
Photo of Curtis Parish
Curtis Parish
  • 3,332 Points 3k badge 2x thumb
If you have a support login and the appropriate access, you can see information about the A2 here.  https://extranet.extremenetworks.com/downloads/pages/A2.aspx     Given that the A2 is no longer supported, you are not going to find updated comparison guides for it and the S4.
The S-Series is the successor of the N-Series, I would not expect incompatibilities with existing A2 switches. If you did not upgrade the N-Series to firmware version 7, you may have to make changes to the configuration before you can use it with the S4.
If you are using 100M fiber connections to the A2 switches, you need to buy 1G fiber I/O modules and 100M SFPs for the S-Series.
Do you have any specific concerns regarding changing the N3 to an S4?
