compatibility with OEM SFP
  • 2
  • Question
  • Updated 3 years ago
  • Answered
I have some X8 and X670 switches with installed SR and LR transievers
    Media Type            : SF+_SR
    Vendor Name           : OPNEXT, INC.
    Part Number           : TRS2001EN-0006
    Serial Number         : 1334A-17101
    Wavelength            : 850 nm
    Media Type            : SF+_LR
    Vendor Name           : SumitomoElectric
    Part Number           : SPP5300LR-EN1
    Serial Number         : 1412L-40020
    Wavelength            : 1310 nm
Where i can find a compatibility matrix with that OEM SFP transceivers or any certification document?So we have problems with that transceivers, which one cause to hang up internal bus, and DOM information can not be readed.
Photo of Artyom Denisov
Artyom Denisov
  • 100 Points 100 badge 2x thumb
Posted 3 years ago
  • 2
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,304 Points 10k badge 2x thumb
Hi Artyom,
You can find which optics are supported on which platform in the EXOS Hardware/Software Compatibility Guide.
More detailed information on these optics is available in the Pluggable Hardware Installation Guide.
-Brandon
Artyom Denisov
Thank you for this links, but i not found there any information about OPNEXT or SumitomoElectric or other vendors of optics that are compatible/certified to use with Extreme swicthes.
As far as I know, there is not a customer-facing document with information regarding the manufacturers of OEM optics.
Both of the optics listed above are Extreme certified and should be supported in the X670 and X8, so if you are experiencing issues with these optics, I would suggest opening a case with GTAC.
-Brandon
