computers lose connectivity after 15 minutes
  • Question
  • Updated 1 year ago
  • Answered
Hello, 2 computers on same subnet can see each each other or can ping but after 10 to 15 minutes they lose the ping and no connectivity is seen between them.. there is no configuration on switch all ports are in default vlan. it is happening with 4 switches right now.
switch is X440 G2
XOS is 21.1.1.x
Photo of Arjumand Qazi
Arjumand Qazi
  • 938 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,414 Points 2k badge 2x thumb
static ip-s or DHCP?
Arjumand Qazi
static IP and there is no conflict between them.
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,888 Points 5k badge 2x thumb
Please check the "show configuration vlan" after the issue occurs and see if flooding is disabled.
Then you are hitting the issue mentioned in the below article, this issue is fixed fromĀ 21.1.1.4 patch 1-5
https://gtacknowledge.extremenetworks.com/articles/Solution/Traffic-is-filtered-by-the-switch-with-d...
Please note that the current recommended version for X440-G2 is EXOS 21.1.3.7
http://www.extremenetworks.com/extreme-hardwaresoftware-compatibility-recommendation-matrices/softwa...
Arjumand Qazi
hello can 16.2.x work ?
I do not think 16.x is an option for X440-G2's the minimum required software version isĀ 21.1.1
Arjumand Qazi
Hello, okay no issues i have upgraded the switch to 21.1.3.7 and its working fine now.
thanks for the support..
cheers
Good to see that the issue is resolved. Thanks for the update.
