Conditional Read statement
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Feb 18 2013 9:55AM
In a script I'm working on I want to check if a variable exists and, if not, prompt the user for a value, like this:
if (!$VAREXISTS(oobmgt_mask)) then<br />&nbsp;&nbsp; &nbsp;set var oobmgt_mask $READ(Mask:)<br />endif
But the $READ statement is executed regardless of whether the variable exists or not, but if the variable exists, the value I enter does not get saved to the variable.
I've tested the if statement, and it correctly detects if the variable exists or not.
Is this a bug or am I doing something wrong?
Edit: Perhaps I should mention that I'm running XOS 12.5.3.9 on a Summit X350-48t.
Best regards
Daniel
(from Daniel_Warhammar)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Mar 13 2013 1:21PM
I've had this issue as well in 15.2.2.7, so you're not alone.
(from pforristal)
