Config changed trap not being received
  • Question
  • Updated 2 years ago
  • Doesn't Need an Answer
Hi All
I have Netsight and XOS 16.1.1. I have set an alarm in Netsight for the following trap
ExtremeNetworks    cfgMgmtConfigChangeTrap    .1.3.6.1.4.1.1916.1.42.10.0.2    Info
ExtremeNetworks    cfgMgmtConfigSaveTrap    .1.3.6.1.4.1.1916.1.42.10.0.1    Info
I  this am however not receiving this trap. Is this supported?
Photo of Justsomebodi
Justsomebodi
  • 1,572 Points 1k badge 2x thumb
Posted 2 years ago
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
Can you do a TCP dump on NetSight to see if the trap is coming in?
Justsomebodi
Hi
I am getting traps to netsight just not those particular ones.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
Are you getting any traps?  If you are, you can try adding the two traps to your SNMP configuration.  and see if that works for you.
configure snmpv3 add mib-view "defaultNotifyView" subtree 1.3.6.1.4.1.1916.1.42.10.0.2 type included
configure snmpv3 add mib-view "defaultNotifyView" subtree 1.3.6.1.4.1.1916.1.42.10.0.1 type included
Justsomebodi
HI
Thanks for the info, That didn't work however.
