Configuration CISCO BGP to EXTREME X460 SWITCH
Raghavendra_vem
Can any one help to convert commanad CISCo BGP to X460 SWitch.
CSCIO COMMANDS:
interface Loopback0 ip address 172.17.23.157 255.255.255.255
interface GigabitEthernet0/0
description ******WAN Connection*****
ip address 172.17.114.157 255.255.255.252
ip helper-address 10.1.224.3
duplex auto
speed auto
interface GigabitEthernet0/1
description *****LAN Connection***
ip address 10.1.224.17 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 10.1.223.17 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/3
ip address 172.17.114.121 255.255.255.252
duplex auto
speed auto
interface Serial0/2/0
no ip address
shutdown
clock rate 2000000
interface Serial0/2/1
mtu 1600
bandwidth 2048
ip address 191.254.225.98 255.255.255.252
encapsulation ppp
no ip route-cache
no fair-queue
clock rate 2000000
router bgp 54321
bgp log-neighbor-changes
network 10.1.223.0 mask 255.255.255.0
network 10.1.224.0 mask 255.255.255.0
network 172.17.23.157 mask 255.255.255.255
neighbor 172.17.114.122 remote-as 9829
neighbor 172.17.114.122 weight 500
neighbor 172.17.114.122 route-map LAN out
neighbor 172.17.114.158 remote-as 9829
neighbor 172.17.114.158 weight 500
neighbor 172.17.114.158 route-map LAN out
neighbor 192.168.5.114 remote-as 18101
neighbor 192.168.5.114 local-as 65001 no-prepend replace-as
neighbor 192.168.5.114 ebgp-multihop 5
neighbor 192.168.5.114 timers 30 90
neighbor 192.168.5.114 soft-reconfiguration inbound
neighbor 192.168.5.114 weight 200
neighbor 192.168.5.114 route-map LAN1 out
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.17.114.158
ip route 10.0.9.0 255.255.255.0 192.168.5.114
ip route 192.168.5.0 255.255.255.0 192.168.5.234
ip route 192.168.5.0 255.255.255.0 192.168.5.114
ip access-list standard SNMP
permit 82.196.34.0 0.0.1.255
permit 82.196.56.0 0.0.0.255
permit 82.196.54.0 0.0.0.255
permit 82.196.32.0 0.0.0.255
permit 130.20.5.0 0.0.0.255
logging facility local0
logging source-interface GigabitEthernet0/1
logging 10.0.15.20
access-list 11 permit 172.17.23.157
access-list 11 permit 10.1.224.0 0.0.0.255
access-list 11 permit 10.1.223.0 0.0.0.255
route-map LAN permit 10
match ip address 11
route-map LAN1 permit 10
match ip address 11
set as-path prepend 65001 65001
snmp-server community 648kkjrddcbcjjcl RO SNMP
snmp-server ifindex persist
snmp-server trap-source Loopback0
snmp-server enable traps snmp linkdown linkup coldstart warmstart
snmp-server enable traps config
snmp-server host 82.196.34.162 RQsfdipXwXnIqwW
snmp-server host 82.196.35.226 RQsfdipXwXnIqwW config
1 REPLY 1
Kevin_Kim
I don't think ExtremeXOS supports the 'neighbor local-as' command. To remove the need of the local-as, the 'remote-as 65001' configuration on the neighbor '192.168.5.114' router needs to be modified to 'remote-as 54321'.
