Configure extreme switch x440-24p-10G
  • Question
  • Updated 3 years ago
  • Answered
Hi guys, I need some help.
We bought a Extreme Summit X440-24p-10G switch and the idea is to create a vlan and to connect with existing LAN using cisco. I have no experience with XOS and  I don ́t know how to set up. where can i get the configuration step or command?
I hope you guys can help me on this., I really appreciate it..
Photo of Mohd Husyairi
Mohd Husyairi
  • 80 Points 75 badge 2x thumb
  • blur
Posted 3 years ago
Photo of Alexandr P
Alexandr P, Embassador
  • 12,192 Points 10k badge 2x thumb
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,950 Points 5k badge 2x thumb
Welcome to the Hub and EXOS.  I attached a link to a article that should help you with this.  I will also give you a example of creating a vlan and adding a port to it.
Configure default del port all # this command will remove all ports from the default vlan.
Create vlan test1 tag 200 # creates vlan with a 802.1q tag of 200
conf vlan test1 add port <port> tagged/untagged
https://gtacknowledge.extremenetworks.com/articles/How_To/Understanding-EXOS-VLANS-and-tagged-and-un...
Mohd Husyairi
thanx for the link guys.. i'm look at it now... really appreciated
