Configure port status "up/down" alarm on netsight and EXOS switches?
  • Question
  • Updated 8 months ago
  • Answered
I need to configure my switches and netsight to give an alarm every time a port state change.
It'd be amazing if I can configure different alarms with different names for different ports!
for example:
-port 1 - alarm1
-port 2 - alarm 2
and so...
Note: I am usin x440 series switches, and Netsight version 7
Regards
Yusuf
Photo of Yusuf Kabbara
Yusuf Kabbara
  • 524 Points 500 badge 2x thumb
Posted 8 months ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,524 Points 5k badge 2x thumb
Hi Yusuf,
You can create different port groups and enable alarm based on the traps received for port up down.
How to create port groups in Netsight
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-and-add-ports-to-a-port-grou...
How to create alarms based on port trap
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-alarms-based-on-traps-in-...
I hope this helps!
Yusuf Kabbara
I added a new group and named it.
entered the device view.... but Selecting the port isn't providing me with the option to add it to group!
Could you help!
Thanks
Yusuf
Yusuf Kabbara
Another thing is happening... when I click on Add button and select Selected Trap Alarm nothing is being displayed on the screen and add button becomes unresponsive!
Thanks for your assistance.
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hi Yusuf,
Also please, configure and enable traps "port-up-down" on your switch.
enable snmp traps port-up-down ports[port_list| all]
https://gtacknowledge.extremenetworks.com/articles/Solution/Port-up-down-alarms-trap-are-not-being-t...
Best regards,
Bin
Hi Yusuf,
I am not in office for a while hence could not check, i will leave this for the other members for further inputs or
I would request you to raise this as a GTAC ticket for further investigation.
Yusuf Kabbara
1 - I enabled the trap on switch ...
#enable snmp traps port-up-down ports all
2 - Created port group...
3 - checking the Trap Reciever ...
All devices --> right click on the device --> Trap Receiver Configuration
Note: # of Receiver is 0
4 - created alarm
Any more steps to be done!?
Thanks
Yusuf
Hi Yusuf,
You are almost there, The trapreceiver with correct credentials needs to be pushed to the switch and then the "snmptrapd" file need a entry.
The two steps are mentioned in the below article.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Configure-SNMPv3-Traps-via-NetSight...
