Configure Virtual controller
  • Question
  • Updated 11 months ago
  • Answered
I have Wings 7502 Ap 14 number  and  i want configure Virtual controller in that please provid the document ... authentication we are going to use RADIUS with external NPS server .
Photo of muthu naganathan
muthu naganathan
  • 202 Points 100 badge 2x thumb
Posted 11 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,132 Points 20k badge 2x thumb
http://www.extremenetworks.com/education/courses/ECS-WiNG-1/
If you think you'd do it without training you could look in the user manual for more information.
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,062 Points 4k badge 2x thumb
The configuration will differ depending on which UI you are running. Can you tell us if you are running Swift UI or Enterprise UI?
 Also, please provide firmware version you're running & full model number of AP.
(Edited)
Photo of Christopher Frazee
Christopher Frazee, Employee
  • 1,508 Points 1k badge 2x thumb
AP7502 does not support Flex (Enterprise) UI. Only the AP7522/AP7532 do.
Photo of Aviv Kedem
Aviv Kedem
  • 1,400 Points 1k badge 2x thumb
Hello muthu naganathan,
You should configure through CLI or with GUI if you have controller (NX, VX, RFS).
Without it you have to dig the equipment well, to troubleshoot the most common adoption and other problems.
I advice to have contract with service provider will do it for you.
Regards,
Aviv Kedem
(Edited)
Hello Muthu,
      We don't have a virtual controller (VC) document for the APs. Basically, you take the AP you wish to have as the VC AP and configured it completely up. The other APs will pull the settings from the VC Configuration (LAN, WAN, Wireless, Security, Services and Management) upon adoption.
You want to test all WLANs and any features you have configured on the VC AP first, prior to bringing on the other APs. Once you have verified full connectivity, proceed to the Configuration/Basic screen on the VC AP and check mark the Virtual Controller box and hit apply.
Prior to bringing on the other APs, you need to ensure that the VC AP is setup to auto-upgrade the adopting APs. All APs must be running the same firmware version in order for VC feature to work as advertise.
Please use the following link to stage the VC to auto-upgrade the adopting APs.
Once all APs are adopted, running same firmware, and valid configuration from VC, you can access the VC UI and under Configuration/Access Points, this is where you can perform static IP overrides and AP name for each AP.
I hope this helps. If not, please have get a support case opened up with us. Thanks.
https://gtacknowledge.extremenetworks.com/articles/Solution/Virtual-Controller-adopted-AP-s-won-t-up...
