Configuring a Landing page on a IdentiFi V2110 controller as replacement for a WM3600 controller
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Dear All
I’m working on a Identify
installation to replace a old Extreme WM wlan installation.
Al is working fine but I have
problems to configure a landing page, can you help me?
On the OLD Extreme WM3600
controllers ( Motorola based ) is the captive portal configured as showed in
the  screen shots below
Vlan 480 is
a bridged on AP
Do you have
a example to configure this, or can you help me to configure the captive portal
with the information as show in the screenshots?
Thank you
Rien van
Maurik
Photo of Rien Maurik
Rien Maurik
  • 260 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,880 Points 20k badge 2x thumb
Hi Rien,
here a link to a document that I've wrote which explains every step...
https://app.box.com/s/p8q9shj6h8po3sc7bxalgm1xuktpsm70
-Ron
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,514 Points 20k badge 2x thumb
Rien,
Do you need any further assistance setting up the captive portal page?
Thanks,
Doug
Rien Maurik
Hello Doug
The information Ron has send help me a bit but not complete.
My problem is still how to translete this WM3600 based captive portal to the Identify base captive portal?
 In the Identify manual or in the example Ron send I don't find  a example to configure a extrenal hosted captive portal liked I did with the WM3600 solution.
Do you have one?
greetings Rien
Photo of Doug Hyde
Take a look at the following guide to see if it helps get your questions answered for external captive portal support: https://extranet.extremenetworks.com/downloads/Pages/dms.ashx?download=a0bbbcfd-4a72-4613-8e02-3c6a6...
(requires extranet login)
Rien Maurik
Hello Doug
I will study the config file
Thank you so far
gr Rien
