Configuring different VLANs for Access Points and WLANs
dot1x
New Contributor II
Hi All,
I'm new to Extreme wireless.
Could someone please assist how can we configure the following:
1. APs get the IP Address from Management Subnet.
2. WLANs users get the IP Address from different subnet than the APs.
Thanks.
7 REPLIES 7
dot1x
New Contributor II
Assuming we have Cisco Switches.
Does the config look good?
Thanks.
Ronald_Dvorak
Honored Contributor
We are sorry to hear that 🙂
It looks OK
just as a reminder.... you'd need a "no shut" on the VLAN interfaces
Madeline
Dear Moin,
I am not sure about the switch that you are using, but from the WiNG AP side, the configuration looks correct
You can do a show IP interface brief on the AP to check the IP address that it is taking
Hope this helps
dot1x
New Contributor II
Hi Madeline,
Thanks for the detailed response. I didn't know if we could configure the AP int Ge interface with switchport commands.
In my case I'd have to configure the following:
AP Ge Interface:
switchport mode trunk
switchport trunk native vlan 10
no switchport trunk native tagged
switchport trunk allowed vlan 10,20
interface vlan 10
ip address dhcp
ip address zeroconf secondary
ip dhcp client request options all
Switchport Config (Where AP is connected)
interface gi1/0/1
The Switch Config:
interface vlan 10
ip address 192.168.10.1 255.255.255.0
ip helper-address
interface vlan 20
ip address 192.168.20.1 255.255.255.0
ip helper-address
Does it make any sense?
