Configuring MSTP between black and purple swithces
  • Problem
  • Updated 2 years ago
  • Solved
Does anyone have any experience with configuring multiple spanning tree instances between C5 switches and the x670.
I have mstp running between two x670s, but want to integrate with a C5. I can supply configs.
Many thanks
Photo of Simon Vosper
Simon Vosper
  • 658 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Zelnosky, Kevin
Zelnosky, Kevin, Employee
  • 1,124 Points 1k badge 2x thumb
Simon,
Go ahead and paste the config outputs and we will take a look at them.
Simon Vosper
Hi Kevin
On the purple side we have :
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-64
configure vr VR-Default add ports 1-64
configure vlan default delete ports 1-64
create vlan "engineering"
configure vlan engineering tag 2
create vlan "finance"
configure vlan finance tag 3
configure vlan engineering add ports 2-3 tagged
configure vlan finance add ports 2-3 tagged
# Module stp configuration.
configure mstp region region1
configure mstp revision 0
configure stpd s0 delete vlan default ports all
disable stpd s0 auto-bind vlan default
configure stpd s0 mode mstp cist
configure stpd s0 priority 4096
create stpd s1
configure stpd s1 mode mstp msti 1
configure stpd s1 priority 4096
create stpd s3
configure stpd s3 mode mstp msti 2
configure stpd s3 priority 8192
enable stpd s1 auto-bind vlan engineering
enable stpd s3 auto-bind vlan finance
configure stpd s0 ports mode dot1d 2
configure stpd s0 ports cost auto 2
configure stpd s0 ports port-priority 128 2
configure stpd s0 ports link-type point-to-point 2
configure stpd s0 ports edge-safeguard disable 2
enable stpd s0 ports 2
configure stpd s0 ports mode dot1d 3
configure stpd s0 ports cost auto 3
configure stpd s0 ports port-priority 128 3
configure stpd s0 ports link-type point-to-point 3
configure stpd s0 ports edge-safeguard disable 3
enable stpd s0 ports 3
configure stpd s1 ports mode dot1d 2
configure stpd s1 ports cost auto 2
configure stpd s1 ports port-priority 128 2
configure stpd s1 ports link-type point-to-point 2
configure stpd s1 ports edge-safeguard disable 2
enable stpd s1 ports 2
configure stpd s1 ports mode dot1d 3
configure stpd s1 ports cost auto 3
configure stpd s1 ports port-priority 128 3
configure stpd s1 ports link-type point-to-point 3
configure stpd s1 ports edge-safeguard disable 3
enable stpd s1 ports 3
configure stpd s3 ports mode dot1d 2
configure stpd s3 ports cost auto 2
configure stpd s3 ports port-priority 128 2
configure stpd s3 ports link-type point-to-point 2
configure stpd s3 ports edge-safeguard disable 2
enable stpd s3 ports 2
configure stpd s3 ports mode dot1d 3
configure stpd s3 ports cost auto 3
configure stpd s3 ports port-priority 128 3
configure stpd s3 ports link-type point-to-point 3
configure stpd s3 ports edge-safeguard disable 3
enable stpd s3 ports 3
enable stpd s0
enable stpd s1
enable stpd s3
ANd on the black side:
#vlan
set vlan create 2
clear vlan egress 1 ge.1.2-3
set vlan egress 2 ge.1.2-3 tagged
#port
set port vlan ge.1.2 2
set port vlan ge.1.3 2
#spantree
set spantree mstcfgid cfgname 'region1'
set spantree msti sid 1 create
set spantree msti sid 2 create
set spantree mstmap 1 sid 1
set spantree mstmap 2 sid 2
set spantree priority 8192 0
set spantree priority 8192 1
set spantree priority 4096 2
The bits i left out were basically default config stuff
Thanks for looking
Simon
Simon Vosper
bump
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,782 Points 10k badge 2x thumb
I don't know if this is still relevant, but the VLAN to instance mapping of the EXOS configuration does not match that of the EOS configuration. Thus the configuration hash does not match and the switches will be in different MSTP regions.
Photo of Martin Flammia
Martin Flammia
  • 5,724 Points 5k badge 2x thumb
Hi Erik,
Have written an post that shows a configuration example of EXOS to EOS MSTP configuration, might help?
http://www.extremenetworks.guru/exos-mstp/
Thanks
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Outstanding work Martin.  Thanks for sharing with the Hub Community!
Martin Flammia
No problem, my pleasure :)
