Configuring OSPF on x620 with AE license
  • Problem
  • Updated 1 year ago
  • Solved
I wish to configure OSPF on a broadcast segment with 2x x620. When I attempted to do this I was surprised to find that if I wanted to set the interface priority to anything other than 0 (not eligable to be DR/BDR) that I am told I am not at a sufficient license level. I have an Advanced Edge license which is surely enough for me to be able to use a IGP.
SW-x620-1.1 # show conf ospf#
# Module ospf configuration.
configure ospf vlan VLAN-10 priority 0
SW-x620-1.2 # configure ospf vlan VLAN-10 priority 1
Error: This command cannot be executed at the current license level.
SW-x620-1.3 # show version
Switch      :
PSU-1       :
PSU-2       :
Image   : ExtremeXOS version 21.1.1.4 21.1.1.4-patch1-5 by release-manager
          on Thu Jun 16 14:19:33 EDT 2016
BootROM : 1.0.1.8
Diagnostics : 5.4
SW-x620-1.4 # show lic
Enabled License Level:
        Advanced Edge
Enabled Feature Packs:
        None
System Type:      X620-16x
I have rebooted after installing the license. Is there something else I need to do?
Any help, much appreciated.
Photo of Paul
Paul
  • 342 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
Advanced Edge license can't be a DR or BDR so the priority has to be 0.  Hope this helps.
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hello Paul,
The advanced edge license allows you to configure OSPF-edge features. Here are the caveats from our user guide:
OSPF Edge Mode is a subset of OSPF available on platforms with an Advanced Edge license.There are two restrictions on OSPF Edge Mode:
• At most, four Active OSPF VLAN interfaces are permitted. There is no restriction on the number of
Passive interfaces.
• The OSPF Priority on VLANs is 0, and is not configurable. This prevents the system from acting as a
DR or BDR.
(Edited)
You could make it P2P if there are only two OSPF devices in the network segment.
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,442 Points 5k badge 2x thumb
Configure the network between your OSPF devices as point-to-point and you do not need DR/BDR feature.
Photo of Paul
Paul
Thank you for your responses, it has clarified the issue.
I was not able to use pt-pt as there were to be be another neighbour on the broadcast segment. I have decided to use VRRP with static routing as I do not want to have the adjacency dependent on only one device.
I feel that for a switch of this value, and having purchased the AE licence it is a bit mean to make this restriction.
