Configuring the ip unnumbered interface
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Photo of Chubak Igor
Chubak Igor
  • 166 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
Hi Chubak,
Just to clarify, are you looking to connect two switches together and have them talk or are you looking for the HSRP setup. HSRP is not a standard and can only be configured on Cisco. You may be looking for VRRP. If this is true here are some articles that should be able to get you started:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Which-command-is-used-to-add-ports-to-a-vlan
https://gtacknowledge.extremenetworks.com/articles/How_To/Configure-IP-address-on-a-VLAN
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-inter-VLAN-routing-in-EXOS
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-a-basic-VRRP-configuration
Hope this helps!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,192 Points 10k badge 2x thumb
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,526 Points 3k badge 2x thumb
Hi Chubak,
Please let us know , what you are trying to achieve on your set up.
Thanks,
Suresh.B
Chubak Igor
Task Extreme?
Create a loopback Interface?
interface loopback 1
IP address 192.168.1.1 255.255.255.0
Create Interface vlan 101
IP address (loopback 1)
Interface vlan 102
Interface vlan 103
Example Cisco:
interface vlan 101
IP unnumbered loopback 1
Interface vlan 102
Interface vlan 103
Patrick Voss, Alum
Hi Chubak,
Based on the output you provided it looks like you are trying to create 3 vlans with vids of 101, 102 and 103. You would like them all to have loopback enabled. If this is true here are the commands below:
create vlan one tag 101
create vlan two tag 102
create vlan three tag 103
configure vlan one ipaddress 192.168.1.1/24
enable loopback vlan one
each vlan has to have its own ip address in a different subnet, like so:
configure vlan two ipaddress 192.168.2.1/24
configure vlan three ipaddress 192.168.3.1/24
Then you can enable loopback on those as well
enable loopback vlan two
enable loopback vlan three
Please let me know if this is what you are looking for.
Photo of Vladimir Chukov
Vladimir Chukov
  • 100 Points 100 badge 2x thumb
(Edited)
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,886 Points 10k badge 2x thumb
Hi Chubak,
Cisco routers provide some special configuration options for serial interfaces. Those do not apply to Ethernet switches, neither for Cisco's nor for Extreme's. You cannot blindly copy a router configuration to a switch.
Br,
Erik
