Configuring SNMPv3
  • Question
  • Updated 5 years ago
  • Answered
Create Date: May 24 2013 1:58AM
I cannot manage switch via snmpv3 - keep giving authentication errors and will not adddoes anyone have a config commands to configure x460 for snmpv3. Is it possible to add the switch via snmpv1 then send commands to configure snmpv3 thru scripts?Thanks
(from David_Kordyban)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: May 29 2013 1:33PM
YES, it is possible. I use Ridgeline and scripts for configure the switches (x450, x460, x480) with snmpv3:
1. connect switch with snmpv1/2
2. on switch create and configure user with cli or script (adjust v3_user, auth_pwd, priv_pwd)
 configure snmpv3 add user v3_user authentication md5 auth_pwd privacy priv_pwd
 configure snmpv3 add group admin user v3_user sec-model usm
3. change your local snmp settings:
- version
- username (v3_user)
- privacy protocol (DES)
- privaciy password (priv_pwd)
- authentication protocol (MD5)
- authentication password (auth_pwd)
4. Try it, I hope it works!
Regards,
Elwood
(from Peter_Eschholz)
