Congestion causing OSPF adjacency loss
  • Problem
  • Updated 3 years ago
  • Solved
  • (Edited)
Experiencing an issue with between a couple of remote sites connected via a LES link that is intermittently loosing its adjacency with each other.
On closer look on one of the ends is experiencing packet loss. Switch ports, Gbics and all cables have been replaced but still seeing packet loss.
On further investigation the packet loss isn't happening incrementally, in seems to happen at a certain point in time. It also seems the problem could be happening most often first thing in the morning.
The suggestion therefore seems to be that it is experiencing congestion.
So my question is how best to mitigate this problem and keep control traffic / OSPF adjacency active?
My understanding is that control traffic like OSPF would automatically be put into a high priority queue (qp8) and therefore shouldn't suffer from this problem. I haven't done a packet capture yet to confirm this but I can see traffic hitting QP8 using the qosmonitor.
Guess we could enable some flow control but wondered if anyone has experienced this before and what you did to resolve it.
Many thanks in advance.
Photo of Martin Flammia
Martin Flammia
  • 6,148 Points 5k badge 2x thumb
Posted 3 years ago
Martin Flammia
Official Response
HI Paul, thanks for posting.
Just to let you know I managed to resolve the issue. The congestion theory didn't hold up when looking closer and I had explored all the other areas I could think of.
In the end it came down to looking at the differences in the configuration between to two end connections.
The differences I found where that one end had Tx & Rx flow control enabled, the other only had Rx (turned off flow control completely on both ports) but what seemed to fix it was one end having jumbo frames enabled and the other (which was experiencing the packet drops) didn't.
Since the change there has been no packet drops and no adjacency drops.
