connect 2 switch with vlan 2 & 3 on each one.then connect them with a hub
  • Problem
  • Updated 1 year ago
  • Not a Problem
how to connect to switch with vlan 2 & 3 on each one.then connect them with a hub that has a pc of vlan 2? the problem is they shouldn't see this pc
Photo of Mahsa
Mahsa
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Mahsa
Mahsa
for example pc1 is in vlan 3. should not ping pc4 in vlan 2 that is connect to hub.
please help
Photo of Chris
Chris
  • 160 Points 100 badge 2x thumb
Im finding it difficult to understand what you want to achieve? if PC1 is connected to switch0 via an access VLAN 3 port you want to know if i can talk to PC4 on vlan 2?? What are the ports configured as on both switches going through to the hub?
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,488 Points 2k badge 2x thumb
use untagged vlan 2 towards the hub or replace hub with a configurable L2 switch
Photo of ARIF ALI Khan
ARIF ALI Khan
  • 60 Points
with the help of router we  will solve the issue
router have a lot of advantages  and present day we have lot of  technology,  why means we sole the issue as soon as possible and work also done fast
Photo of Yusuf Kabbara
Yusuf Kabbara
  • 524 Points 500 badge 2x thumb
As long as the switch ports connected to the hub are on vlan 2 and configured as access port. I don't think you will have a problem.
