Connect 4 Wireless Controller
  • Question
  • Updated 6 months ago
  • Answered
Hi all,
My company has 4 Wireless Controller C35 to manage 190 Access Points . I want to centralized management all AP. Please give me solution to connect 4 WC.
Photo of Long Tran
Long Tran
  • 616 Points 500 badge 2x thumb
Posted 8 months ago
Photo of Jacob, Praveen
Jacob, Praveen, Employee
  • 1,022 Points 1k badge 2x thumb
You can configure the 4 Controllers to operate in two High Availability (HA) pairs. The APs can then be distributed across the two pairs of WCs.
Hope this helps.
Photo of Long Tran
Long Tran
Thanks Jacob,
You can explain more clearly?
Photo of Nathiya Munuswamy
Nathiya Munuswamy, Employee
  • 1,672 Points 1k badge 2x thumb
Photo of Long Tran
Long Tran
Hi Nathiya Munuswamy,
High Availability mode is used for 2 Wireless Controller. My company has 4 WC. Solution to connect 4 WC?
Photo of Elvin Manumbale
Elvin Manumbale
  • 150 Points 100 badge 2x thumb
Hi Nathiya,
Is is possible to assign one public IP to HA Wireless controller ?
Currently we set up one controller and manage remote access point via public IP.
Photo of Jordi Soler
Jordi Soler
  • 584 Points 500 badge 2x thumb
You can use Netsight Console -> Wireless Manager to manage all controllers from a single place. You still will have 2 Availability pairs. Also, make sure you configure a Mobility Domain, to allow for sessions and roaming to work across all 4 controllers.
From OneView, I don't know if this option to manage all 4 controllers is possible.
Hope it helps.
Photo of Bin
Bin, Employee
  • 5,076 Points 5k badge 2x thumb
Hi Long Tran,
Add user guide from Wireless Manager.
Best regards
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 42,280 Points 20k badge 2x thumb
Here a link to a very old post with a screenshot of Netsight/Oneview with multiple controller in one browser window.
To make it clear.. you still need to configure both contoller pairs separate but could do it in one browser window.
It recommend to switch to a VM controller pair instead of 4x C35 if that is possible in your network design.
