Connect Extreme Location?
  • Question
  • Updated 5 months ago
  • Answered
Hi all,
I am testing ExtremeLocation.
But My AP (AP7522) can't connect to us.extremelocation.com although I followed the guide: ExtremeLocation Quick Start Guide.
Note: I opened port 443 in Modem/Router. But AP can't connect to extremelocation
Help me please.
Thanks
Photo of Long Tran
Long Tran
  • 666 Points 500 badge 2x thumb
Posted 5 months ago
Photo of Slava Dementyev
Slava Dementyev, Employee
  • 200 Points 100 badge 2x thumb
Hi, have you checked if the AP can resolve feeds-us.extremelocation.com?
Just try pinging this address from the AP itself.
which version are you running on the AP?
Thanks,
Slava
Photo of Long Tran
Long Tran
Hi Dementyey,
How to check AP?
AP 7522 is running firmware 5.9.1.4.
Thanks
1. SSH to the AP
2. Ping feeds-us.extremelocation.com
Photo of Long Tran
Long Tran
Hi Dementyey,
Test result.
ap7522-19F630#ping feeds-us.extremelocation.com
PING lsense-elb-classic-prod-705677272.eu-central-1.elb.amazonaws.co (18.195.156.163) 100(128) bytes of data.
--- lsense-elb-classic-prod-705677272.eu-central-1.elb.amazonaws.co ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4036ms
Photo of Long Tran
Long Tran
What should I do next?
And I use nslookup feeds-us.extremelocation.com for result:
" Non-authoritative answer:
Addresses:  18.195.156.163
          35.156.143.49
          52.28.164.123
Aliases:  feeds-us.extremelocation.com "
And I ping to 18.195.156.163; 35.156.143.49; 52.28.164.123. But can't.
How to fix  it?
Thanks
(Edited)
