Connection between Transceiver MGBIC-LC03 and 10060 !
Frank_Seidler
I'm searching for experience with the Connection between an switch EOS A4H with MGBIC-LC03 and a XOS Summit X450-G2 with a 10060 Transceiver over a 62,5 OM1 fiber. We just want to use this Connection over a distanz of 1 until 2 km with 1000Base LX. According to the data sheet it should work within the 1310 NM window?
Thanks Frank
1 REPLY 1
Brian_Austin
Hey Frank it appears your problem with with the 10060 transceiver as it is only good up to 550m using 1Gb according to the following:
http://documentation.extremenetworks.com/pluggable/PluggableHardware/miniGBIC/r_dualspeed-100fx1000l...
