Connection times out when controller tries to update AP firmware?
  • 2
  • Question
  • Updated 1 year ago
  • Answered
AP 7522 (Internal) Firmware: 5.8.5.0
VX9000e Firmware: 5.8.6.5
When controller is set to AutoUpdate AP firmware it keeps timing out trying to update AP firmware?
Get this message: "ap7522-xxxxx . %FWU-3-FWUCOULDNOTGETFILE: Firmware update unsuccessful, couldn't get file, Error reciving file from server af XXXXXXX bytes: Connection timed out
Does anyone have a solution?
Thanks
Photo of Martin Sørensen
Martin Sørensen
  • 154 Points 100 badge 2x thumb
Posted 1 year ago
  • 2
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
Do you check the connection? Maybe it's a connection problem. Is it a WAN connection, I get some problem with bad MTU sizes. In this case you need to change the MinT MTU size (if the update is performs via MINT?).
Do you use the express or non express? VX9000e is express, AP7522 is non express, this won't work. Or it's the AP7522e?
Martin Sørensen
Hi, Thanks
The APs are 7522E
The manager is VX9000E.
I have tried to set MTU to 1386? Stil the same problem:
The AP also wont adopt site configuration.
Thanks,
Photo of Andrew Webster
Andrew Webster
  • 1,868 Points 1k badge 2x thumb
It sure sounds like an MTU problem.  Try lowering MTU to 1200 or lower to see if that makes a difference.
Also make sure there is no firewall blocking UDP port 24576.
Photo of Christopher Frazee
Christopher Frazee, Employee
  • 2,086 Points 2k badge 2x thumb
I would collect tech-supports from the VX9E and AP that is not upgrading and open a support case for us to review. Use the following article to export tech-support files from WinG 5 devices:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Collect-a-Tech-Support-file-from-Wi...
Photo of Aviv Kedem
Aviv Kedem
  • 1,714 Points 1k badge 2x thumb
Hello Martin,
I can advice to make standalone upgrade with FTP that includes an application error correction mechanism.
 Regards,
Aviv
