Connectivity issue with A4 (Gig port) & C5
  • Question
  • Updated 4 years ago
Hi Team
We are getting issue in switching between A4 switch to C5 Switch issue is whenever we set the port speed of both interconnected port to 1000mpbs then link get disconnect and when we keep it 100Mbps then only it works. We did all the possible configuration changes but issue remains same.
Why is it happing ? is it know problem ?
Photo of SB
SB
  • 202 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,004 Points 20k badge 2x thumb
I'd confirm your findings but why not let the ports to negotiation enabled.
In that case port negotiation set the port to 1000 full and the ports went up.
A4(su)->show port status ge.1.25          Alias        Oper    Admin   Speed
Port      (truncated)  Status  Status  (bps)     Duplex  Type
ge.1.25                Up      Up      1.0G      full    BaseT RJ45
A4(su)->
C5(su)->show port status ge.1.24          Alias        Oper    Admin   Speed
ge.1.24                Up      Up      1.0G      full    Combo RJ45/SFP
C5(su)->
So on my c5 on port ge.1.24.....
set port speed ge.1.24 10
set port duplex ge.1.24 half
set port negotiation ge.1.24 enable
On the A4 to use port ge.1.25 first you need to do...
set switch stack-port ethernet
then after the reboot..
set port speed ge.1.25 10
set port duplex ge.1.25 half
set port negotiation ge.1.25 enable
And the port should come up with 1000.
If it doesn't work could you try back to back with a patch cable.
I had some troubles in the past with bad cabling in our building and never got 1000 in such case.
