Console Connection to an x440-8?
  • Question
  • Updated 2 years ago
  • Answered
Excuse my ignorance, but I am having my first experience with an x440-8.  Can I ask how do you console to the device?  I need to complete the initial configuration of the device and can't seem to figure out how to connect to it.
Thanks,
Stan
Photo of Stanley Riley Jr.
Stanley Riley Jr.
  • 950 Points 500 badge 2x thumb
  • confused
Posted 2 years ago
Photo of Roger Green
Roger Green
  • 200 Points 100 badge 2x thumb
use an rs-232 (serial cable) into the console port. Use a term emu program such as secureCRT or hyperterminal. set up com port settings 8,1, no flow control.
Photo of Drew C.
Drew C., Community Manager
  • 37,336 Points 20k badge 2x thumb
Hi Stanley,
Does this article help: How to console into Extreme and Enterasys switches
Do you have a serial port or a serial to USB adapter?
Depending on the version that shipped with the switch, it may have Zero-Touch Provisioning enabled, which will automatically assign an IP address from DHCP to the mgmt port or to one of the other front-panel ports.  That IP address will be displayed, one number at a time, in the stacking LED window.  If DHCP isn't available, it will display its link-local address.
(Edited)
Stanley Riley Jr.
Not to sound silly, but there is no serial console port on the switch, only an ethernet port.
Photo of Drew C.
  • 37,322 Points 20k badge 2x thumb
No problem, Stanley.  Take a closer look  :)
http://documentation.extremenetworks.com/summit_16/Summit_Family_HW_Install/Switch_ovrvu/c_summit-x4...
The Serial console port is implemented as an RJ-45 connector.  The switch should have came with a purple cable and a purple adapter to use for this.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
It looks like a ethernet port right under the management port on the left side of the switch.
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Just sharing the cable picture so everyone can have it with details. :-)
Stanley Riley Jr.
OK, just to note, I'm trying to work on this remotely.  I do have remote hands helping me get it setup, and he was able to find the RJ-45 adapter.
What do I do if the stacking LED is blank?  It's not showing any IP or link-local address.  :(
Photo of Drew C.
It most likely means it didn't ship with a version that included this feature.  Not a problem.
Stanley Riley Jr.
So then is there a default IP address or something?
Stanley Riley Jr.
oooo, I got it!  It was on COM5.
Thanks everyone for your help!!!
Photo of Darren Saliva
Darren Saliva
  • 662 Points 500 badge 2x thumb
i found that using any RJ45 to serial console cable that isn't the one that comes with the x440 switches does not work.
