Controller not reporting AP status correctly
  • Problem
  • Updated 2 years ago
  • Solved
My C5210 controller is showing that an AP has 0 active clients and that Radio 1 & 2 which are set to "Auto Power" states that "Current TX Power Level" is Off.  When I look at the switch port , it clearly shows numerous clients on that AP port.  Also in OneView, I can see that there are numerous clients on both Radio 1 & 2 actively connected.  I've tried hard setting the power level and also rebooting the AP and it still didn't fix it.  Any thoughts on what the cause may be?
The AP is an AP3610 running 09.15.02.0009
Photo of Rich Pacheco
Rich Pacheco
  • 934 Points 500 badge 2x thumb
Posted 3 years ago
