Cooler / Fan replacement form Summit x350 48T
  • Problem
  • Updated 3 years ago
  • Solved
Hi all,
My x350 48T show a problem with a cooler/fan number 7, this cooler is very very noise and show many messages in the log alternating between OPERATIONAL and FAILED.
07/26/2015 21:06:55.92 <Warn:DM.Warning> Switch, Error 5: Fan #7 operational. Rpm 1000 is back to operating range (from 1000 to 1000 rpm). (X350-48t, P/N: 800243-00-03, S/N: 1047G-80603, Rev: 3.0)
07/26/2015 21:06:25.91 <Warn:DM.Warning> Switch, Error 4: Fan #7 failed. Rpm 0 is out of operating range (from 1000 to 1000 rpm). (X350-48t, P/N: 800243-00-03, S/N: 1047G-80603, Rev: 3.0)
I try found it but no sucess. I saw a post that show a cooler 80x80x25 Elida Fan as compatible, it is true?
It ́s ease to replace the fan from x350?
Best regards,
Gustavo
Photo of Luiz Gustavo Villamarim Morgado
  • 70 Points
  • confused
Posted 3 years ago
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
Hi Gustavo,
I can't recommend that you replace the fan directly, but it looks like that switch would be covered under warranty.  That allows you to get you a replacement switch instead of replacing the fan and voiding warranty.
You'll want to open a case with GTAC so they can confirm that you're covered and help get a replacement out.
How to contact Extreme Networks Global Technical Assistance Center (GTAC)
Return Material Authorization RMA Process and FAQ
Please let me know if this is helpful.
-Drew
Photo of SHUBHAYAN GHOSH
SHUBHAYAN GHOSH
  • 70 Points
Can you advise if we will need to shut down the switch to remove the fan or not ?
Photo of Drew C.
If the fan is a field replaceable one (not built in), you will not need to power off the switch.
SHUBHAYAN GHOSH
  • 70 Points
