cpu light red
  • Question
  • Updated 4 years ago
 A4 Cpu light  flashes red and all the lights for the connecting  computers are off.  Can’t login by console port. Unplug the power and restart the switch. The fault goes recovery and the switch is working on. But after a few hours, the fault is coming again. Unplug the power and restart  to fault recovery. show support info:
<57> JUN 26 11:53:43 2014 STK1 BOOT[268430624]: bootos.c(1360) 18 %% Start of Code - Build:06.61.07.0010  Date:Fri Oct 19 18:47:59 2012
<57> JUN 26 13:31:27 2014 STK1 BOOT[268430624]: bootos.c(1360) 19 %% Start of Code - Build:06.61.07.0010  Date:Fri Oct 19 18:47:59 2012
<162>Jun 26 13:31:58 0.0.0.0-1 SIM[177510400]: edb.c(495) 19 %% EDB Callback: Unit Join: 1.
<110> JUN 26 13:32:29 2014 STK1 BOOT[126531120]: edb_bxs_api.c(778) 21 %% Last switch reset caused by power cycle
<57> JUN 26 13:48:02 2014 STK1 BOOT[268430624]: bootos.c(1360) 22 %% Start of Code - Build:06.61.07.0010  Date:Fri Oct 19 18:47:59 2012
<162>Jun 26 13:48:33 0.0.0.0-1 SIM[177510432]: edb.c(495) 22 %% EDB Callback: Unit Join: 1.
<110> JUN 26 13:49:04 2014 STK1 BOOT[126531120]: edb_bxs_api.c(778) 24 %% Last switch reset caused by power cycle
<57> JUN 26 13:54:26 2014 STK1 BOOT[268430624]: bootos.c(1360) 25 %% Start of Code - Build:06.61.07.0010  Date:Fri Oct 19 18:47:59 2012
BackTrace-check sum corrupt        <162>Jun 26 13:54:58 0.0.0.0-1 SIM[177510704]: edb.c(495) 25 %% EDB Callback: Unit Join: 1.
<110> JUN 26 13:55:29 2014 STK1 BOOT[126531408]: edb_bxs_api.c(778) 28 %% Last switch reset caused by Fault(0x00001100) SRR0(0x0117366C) SRR1
(0x20009030) DMISS(0x24000038) IMISS(0x00000000) DAR(0x00000000) DSISR(0x00000000)  <57> JUN 26 13:56:31 2014 STK1 BOOT[268430624]: bootos.c(1360) 29 %% Start of Code - Build:06.61.07.0010  Date:Fri Oct 19 18:47:59 2012
<162>Jun 26 13:57:02 0.0.0.0-1 SIM[177510400]: edb.c(495) 29 %% EDB Callback: Unit Join: 1.
<110> JUN 26 13:57:33 2014 STK1 BOOT[126531120]: edb_bxs_api.c(778) 31 %% Last switch reset caused by power cycle
<57> JUN 26 15:20:55 2014 STK1 BOOT[268430624]: bootos.c(1360) 32 %% Start of Code - Build:06.61.07.0010  Date:Fri Oct 19 18:47:59 2012
<162>Jun 26 15:21:26 0.0.0.0-1 SIM[177510400]: edb.c(495) 32 %% EDB Callback: Unit Join: 1.
<110> JUN 26 15:21:57 2014 STK1 BOOT[126531144]: edb_bxs_api.c(778) 34 %% Last switch reset caused by power cycle
<57> JUN 26 16:18:55 2014 STK1 BOOT[268430624]: bootos.c(1360) 35 %% Start of Code - Build:06.61.07.0010  Date:Fri Oct 19 18:47:59 2012
<162>Jun 26 16:19:26 0.0.0.0-1 SIM[177510416]: edb.c(495) 35 %% EDB Callback: Unit Join: 1.
<110> JUN 26 16:19:57 2014 STK1 BOOT[126531120]: edb_bxs_api.c(778) 37 %% Last switch reset caused by power cycle
<57> JUN 26 16:50:50 2014 STK1 BOOT[268430624]: bootos.c(1360) 38 %% Start of Code - Build:06.61.07.0010  Date:Fri Oct 19 18:47:59 2012
<162>Jun 26 16:51:21 0.0.0.0-1 SIM[177510432]: edb.c(495) 38 %% EDB Callback: Unit Join: 1.
<110> JUN 26 16:51:52 2014 STK1 BOOT[126531120]: edb_bxs_api.c(778) 40 %% Last switch reset caused by power cycle
<57> JUN 26 16:52:16 2014 STK1 BOOT[268430624]: bootos.c(1360) 41 %% Start of Code - Build:06.61.07.0010  Date:Fri Oct 19 18:47:59 2012
<162>Jun 26 16:52:47 0.0.0.0-1 SIM[177510400]: edb.c(495) 41 %% EDB Callback: Unit Join: 1.
<110> JUN 26 16:53:18 2014 STK1 BOOT[126531120]: edb_bxs_api.c(778) 43 %% Last switch reset caused by power cycle
Photo of wangxiaohui
wangxiaohui
  • 90 Points 75 badge 2x thumb
Posted 4 years ago
Photo of Jason Parker
Jason Parker, Employee
  • 3,038 Points 3k badge 2x thumb
Please call into the GTAC and they will help you. In most cases this could be a RMA
Jason
