CRC error monitoring via SNMP
  • Question
  • Updated 2 weeks ago
We are trying to execute in SNMP to get realtime CRC errors via snmp walk
I found the oid with details with this link
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-is-the-OID-for-monitoring-CRC-errors-on-...
but when we are trying to execute snmpwalk, we are getting this result, hence not able to conclude how to get the details port wise
Below is the o/p in the tool
D:\Program Files (x86)\HP\HP BTO Software\bin>nnmsnmpwalk.ovpl 10.45.203.29 1.3.6.1.4.1.1916.1.11.1.1.3
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.1 : Counter: 0
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.2 : Counter: 0
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.3 : Counter: 0
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.4 : Counter: 0
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.5 : Counter: 0
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.6 : Counter: 0
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.7 : Counter: 0
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.8 : Counter: 0
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.296 : Counter: 1809
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.778 : Counter: 0
extremeRtStatsTable.extremeRtStatsEntry.extremeRtStatsCRCAlignErrors.779 : Counter: 0
Photo of Saurabh Makkar
Saurabh Makkar
  • 262 Points 250 badge 2x thumb
Posted 3 weeks ago
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,388 Points 3k badge 2x thumb
Hi Saurabh,
Do you have rmon enabled on the switch? This will allow the switch to collect the information and make it available to the SNMP process. The command for doing so is "enable rmon" and doesn't need to be enabled on a per-port basis.
Thank you,Brad
Saurabh Makkar
rmon is already enabled the o/p is also correct
Just the decoding of o/p was a challenge here, now i decoded it :)
Thanks
Here is the decoding
the result shown in SNMP walk from nms tool is correct however the decoding of the o/p is little tricky here.
Each slot has a reserved number for representation of ports ,namely 256 , so the actual number represented would be ( slot # - 1)*256 + actual port # .
One odd and one even (One pair) matches to one physical port.
In below setup, 259 and 260 match to port 2:2, 261 and 262 match to port 2:3, 1537 and 1538 match to MSM128 management port(slot 7).
Below is the information
* BD-8806.1 # show slot
Slots    Type                 Configured           State       Ports  Flags
Slot-1   G48Tc(PoE)           G48Tc(PoE)           Operational   48   M
Slot-2   10G4Xc               10G4Xc               Operational    4   M
Slot-3                                             Empty          0
Slot-4                                             Empty          0
Slot-5                                             Empty          0
Slot-6                                             Empty          0
MSM-A    8900-MSM128                               Operational    0
MSM-B                                              Empty          0
BD8800 with slot1 G48TC and slot2 10G4XC
Name/OID: extremeRtStatsCRCAlignErrors.1; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.2; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.3; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.94; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.95; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.96; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.257; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.258; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.259; Value (Counter32): 29412027
Name/OID: extremeRtStatsCRCAlignErrors.260; Value (Counter32): 1790583109
Name/OID: extremeRtStatsCRCAlignErrors.261; Value (Counter32): 419320560
Name/OID: extremeRtStatsCRCAlignErrors.262; Value (Counter32): 4100373752
Name/OID: extremeRtStatsCRCAlignErrors.263; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.264; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.1537; Value (Counter32): 0
Name/OID: extremeRtStatsCRCAlignErrors.1538; Value (Counter32): 0
