create a 801.1q trunk on the fiber to connect the two switches
  • Question
  • Updated 4 years ago
  • Answered
Hi Folks,
I'm trying to setup a vlan between a pair of summit 200/48's.  So far I've got the vlan configured on both ends, I've configured the ports on both ends, and I'm stuck on creating a 801.1q trunk.
Can anyone point me in the right direction?
Photo of Tourless
Tourless
  • 100 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello tourless. You need to configure the VLANs with a tag using the command configuration tag . Then add your up link port to each VLAN as a tagged port using the command configuration add port tagged.
Let me know if you need more help?
P
Photo of Tourless
Tourless
Hi Paul, and thanks for the reply.  I previously created the vlan and added a port as follows...
create vlan 3
config 3 tag 3
config 3 add port 12 tagged
config 3 ipaddress 10.0.0.1/24
I did the same on both switches.
Not sure if it matters but I probably mention this is for voice traffic... I'm trying to dedicate one port on each switch for a direct dial phone line that is being used as a fax.
Photo of Paul Russo
Paul Russo, Alum
Hey Tourless it doesn't matter for VOIP so it looks great are there any other questions?
P
Photo of Tourless
Tourless
I'm not getting a dial tone through it... do I have to set static IP's on the ports on each end?  such as 10.0.0.2 and 10.0.0.3 respectively?
I don't think it's VOIP... I think it's an analog line brought in from our cable provider... if that matters.
Photo of Tourless
Tourless
well I just confirmed with my provided that from the jack on the modem to the phone it is converted to analog so I don't think this is going to work.
