Create Layer 3 Interface
Kevin_Craig
Hello, I am looking to assign an IP address directly to an interface opposed to creating a SVI. Is it possible to create a Layer 3 interface within EXOS? Similar to the "No Switchport" command within Cisco IOS.
Kevin,
3 REPLIES 3
Kevin_Craig
Thanks for the explanation Stephen, makes sense when you put it that way.
Patrick, thanks for the advice, that was my backup plan if creating a Layer 3 interface wasn't an option.
Kevin,
StephenW
Kevin,
One thing different is EXOS switches share a single MAC we use for all ports.
Stephen
Patrick_Voss
Hello Kevin,
You can add an IP address to a VLAN and only add in one port. This essentially gets you what you are looking for.
Here are some articles that should help you get started:
https://gtacknowledge.extremenetworks.com/articles/How_To/Create-VLAN-in-EXOS/?q=create+vlan&l=e...
https://gtacknowledge.extremenetworks.com/articles/Q_A/Which-command-is-used-to-add-ports-to-a-vlan/...
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-inter-VLAN-routing-in-EXOS/?...
Hope this helps!
