Create Sub-interface on X440 switch??
  • Question
  • Updated 2 months ago
  • Answered
Is it possible to create sub-interface on extreme X400 switches?
Photo of Alok Shukla
Alok Shukla
  • 340 Points 250 badge 2x thumb
Posted 2 months ago
Photo of Eric Burke
Eric Burke
  • 3,288 Points 3k badge 2x thumb
Alok, are you talking about simply adding a vlan to a port?
Alok Shukla
Yes Eric, We want to create sub-interfaces on a single Ethernet port.
Photo of Eric Burke
Eric Burke
First, create the new vlan "create vlan v10 tag 10"
Then add it as a tagged interface to an existing port "conf vlan v10 add port 5 tagged"
Once you define an object in EXOS (like v10), you can even leave off the qualifier and make it simply "conf v10 add port 5 tagged". Repeat the two lines for each subinterface you wish to add to the port.
Photo of Eric Burke
Eric Burke
I should add, some older (I think) versions don't allow the tag addition when creating the new vlan. Those are done with two entries:
create vlan "V11-LegacyLan1"
configure vlan V11-LegacyLan1 tag 11
Then add the port to the vlan as tagged: conf v11-LegacyLan add port 5 tagged
