Creating Stack of connected cascade switches?
Alok_Shukla
New Contributor III
we have X440-G2 switches in our production environment and these switches are connected in a cascade manner, Does any Pre-configured switch need changes for doing stacking. or we have to make fresh configuration?
2 REPLIES 2
Claudio_D_Ascen
New Contributor III
Hi Alok,
when you configure in stack two or more switches the configuration will be erased and you have to make a new configuration for all the stack.
The port numbers change from 1, 2, 3, etc. to 1:1, 1:2, ... Slot/port.
Regards
Claudio
Larry_Kunz
Hi, Alok. For stacking, Extreme Networks strongly recommends that the switches be connected in a ring topology rather than a daisy-chain or cascade topology. In a ring topology, if one of the connections goes down, you're less likely to encounter a dual-master situation and nodes are less likely to be isolated from the stack.
Typically you can change a daisy chain to a ring topology simply by adding a physical connection between the last switch in the chain and the first one as shown here. (Note the connection between the top switch and the bottom switch.)
a56f4d2521c44505a413bc1d7187adee_RackMultipart20180226-13912-cm65fl-ring_topology_inline.png
Larry Kunz
Information Development
Extreme Networks
