Creating a Port Channel/Lag from Cisco to Enterasys
  • 3
  • Question
  • Updated 2 years ago
  • Doesn't Need an Answer
My name is Gary Rollie I am a Global Solution Engineer, I have a CCIE, JNCIE, as well as many other certs and publications. I currently work for Enterasys and have worked here for the past 6 years.
On the ETS side it’s really simple.
SSA-150-Fiber(su)->set lacp enable
SSA-150-Fiber(su)->set port lacp port ge.1.1-12 enable
This sets ports ge.1.13 to ge.1.24 to process lacp. This is the simplest way to make it work quickly. The more secure way is to define the ports and use a static lag. That said to convert it from dynamic to static doesn't take the lag down, so it can be a follow up task after the lag is established.
On the Cisco side it’s a little more complicated. On the Cisco Switch these commands work across almost all models of the Cisco Switch line.
CORE-HOU-01#conf t
CORE-HOU-01(config)#interface range gigabitEthernet 0/49 – 52
I use the interface range command here to make the changes to 4 interfaces; this is similar to our ge.1.1-4 command.
CORE-HOU-01(config-if-range)#lacp port-priority 888
I picked 888 any number from 1-65535 works this allows the port to join the lacp group
CORE-HOU-01(config-if-range)#channel-group 1 mode active
The Active part of the channel group command sets up the port channel on the Cisco side to talk LACP, if you don't do that the Cisco will revert to PaGP (Cisco proprietary protocol.
Note: if you have a channel-group 1 defined this ports will be added to that channel-group if you have not created channel-group 4 the Cisco will automatically create an interface called po1/4
This is the output
Creating a port-channel interface Port-channel 1
Photo of Gary Rollie
Gary Rollie
  • 90 Points 75 badge 2x thumb
Posted 5 years ago
  • 3
Photo of Claire O'Keeffe
Claire O'Keeffe
  • 60 Points
Hi! What has channel-group 4 got to do with it? :D
We're struggling to bring up a PC between Cisco 3750 and Enterasys. LACP is enabled on both side but the cisco is receiving very few LACP PDUs. e.g. 5 in for every 135 out. Any ideas?
(Edited)
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,782 Points 10k badge 2x thumb
Hi Claire,
the default LACP timers are set to send one LACP PDU every 30s. The short or fast timers change this to one PDU every second. Both values are standardized and can usually be configured on the devices. If the timers don't match, the LAG will flap.
Edit: See e.g. How to Configure Dynamic LAGs with LACP on Securestack or Chassis based switches for information on EOS LAG configuration.
Erik
(Edited)
