cset AP, controller looses antenna selection
  • Question
  • Updated 1 year ago
  • Answered
could someone try to see whether that is a general issue....
AP3825e running 10.31 (ROW)
If you cset the AP and the AP connects again to the controller the antenna selection is gone and I need to set the right antennas (and also set the radios to admin mode on) again.
In my opinion that shouldn't happen as the controller shouldn't loose that setting.
I've only tried it with a AP3825e but it could be that it's the same with other AP models with external antennas.
Thx,
Ron
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,120 Points 20k badge 2x thumb
Posted 1 year ago
That's the log message that I get after the reconnect of the AP....
06/14/17 16:12:26 Minor Config Manager Invalid configuration request for Wireless AP [14496737085F0000]. Changed parameters: channel list was changed.
Photo of Chris Taylor
Chris Taylor
  • 796 Points 500 badge 2x thumb
That happened to us as well but not consistently. 2 APs we use on a temporary basis lost their "professional installation" antenna selection. They were fine once we put the settings back in. The next time we went to use them they did not lose the configuration so we chalked it up to a fluke.
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hello Ronald,
It seems to link this script.
Access point radio Admin Mode shows off after an antenna model change
https://gtacknowledge.extremenetworks.com/articles/Solution/Access-point-radio-Admin-Mode-shows-off-...
Regards
Bin
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
Ron,
I will discuss with engineering what the expected behavior is. I assume you are doing a cset factory?
Yes sorry missed the factory :-)
Photo of Doug Hyde
No problem, I just wanted to make sure we replicate it with your exact process.
Photo of Doug Hyde
Ron,
Here is how it works currently...
External antenna parameters are considered as static ap properties similar to static ip address and it gets reported back to a controller during discovery.
Cset factory removes the ap’s running configuration and the ap goes into discovery looking for a controller.  The default external antenna setting is "no antenna" so this gets reported back to the controller accepting this ap.
The controller will have to reconfigure the external antenna settings again.
Photo of Doug Hyde
Thanks Doug,
could you please be so kind and tell the guys that that makes no sense.
Is there a list of "static AP properties" so I know what other parameters in my centralized mgmt (=controller) are not permanent.
Photo of Doug Hyde
Understood, I will see if we have a list  Ron.
