Current stable iOS for switches ?
  • Question
  • Updated 2 years ago
  • Answered
We have black diamond and 400 series switches all running on 12.5. 4.5
What is the current stable iOS.
What versions should I start upgrading to from 12.5.4.5 to reach latest one.
Photo of Sai Prasad Rao Rapolu
  • 1,494 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Ron Huygens
Ron Huygens, Employee
  • 2,878 Points 2k badge 2x thumb
You can look at the following ink for the recommended EXOS versions per platform
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-Is-The-Recommended-Release-of-EXOS-For-M...
You also want to check out if your devices does not already reached end-of-life.
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-are-the-end-of-sales-life-and-end-of-sup...
In that case you won't be able to upgrade.
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
You should not need any intermediate EXOS version from 12.5 to the recommended release.
However, I would recommend you to read the EXOS User Guide and Release Notes for more detailed information.
You can download both documents using the links below:
http://www.extremenetworks.com/support/documentation/ http://www.extremenetworks.com/support/release-notes/
Hi
Thanks All for sharing Info
Currently we have BlackDiamond switches running on 12.5. 4.5
We have X460 switches (stack) running on 12.5.4.5, stable release as per above shared docs for 460 is 16.1.3.6-patch1-9
Can I directly upgrade to 16.1.3.6-patch1-9  ?
(Edited)
