D-Series Dropping Telnet Sessions
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 11405
Products
D-Series, firmware 1.00.04.0001 and lower
Changes
Established a Telnet session to the switch host.
Symptoms
The Telnet session drops, possibly while the user is typing into the CLI.
The Telnet session worked for awhile, then failed.
The length of time a session lasts before being dropped is random.
Below is an example of what a user might see. In this case the user was in the middle of typing a 'show port status' command when the Telnet session was lost.
         D2(su)->show port s
    Connection to host lost
    C:\Documents and Settings\myuser>
    Cause
    This is due to the presence of a large number of ARP packets being forwarded.
    Solution/Workaround
    Upgrade to firmware 6.03.01.0008 or higher, then utilize the CPU Rate Limiting 'hostprotect' command set as explained in 11765
    Pre-upgrade workaround: Restart the Telnet session, or use SSH or the Serial console.
    Photo of FAQ User
    FAQ User, Official Rep
    • 13,620 Points 10k badge 2x thumb
    Posted 5 years ago
    There are no replies.
