D-Series f/w 6.03.10.0003 erroneously reports Fan Failure error
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 14536
Products
D-Series, firmware 6.03.10.0003 and lower
D2G124-12, D2G124-12P
Symptoms
Fan Failure messages and traps are sent to the console, logs, and network management; for example:
Jan 5 08:00:47 172.16.21.201-1 SIM[67451624]: hwutils.c(4292) 62397 %% FAN2-is NOT Functional
Cause
With this product; the fans only run occasionally, when needed for cooling under relatively extreme conditions (14554).
It is possible for the fans to have just hardware-cycled off, but the software has not yet detected it. During the period of time in which the fan status is still listed as "Ok" yet the fans are no longer spinning, the system may in error report a "FAN1-is NOT Functional" or "FAN2-is NOT Functional" condition.
Solution/Workaround
Upgrade to firmware 6.03.11.0004 or higher.
If the symptoms persist after upgrade, then please contact the GTAC for assistance.
Workaround:
Manually determine whether or not the switch fans have failed, based on either non-operation during system boot or non-operation while the system is hot.
Photo of FAQ User
FAQ User, Official Rep
  • 13,620 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
