DB9 Console cables for C5 and B5 switches
  • Question
  • Updated 1 year ago
  • Answered
I am looking for information for an adapter to use with our C5G and B5 switches for the console port.  We have a couple of aging laptops let with Windows Vista that have a serial port on them and I want to get away from those laptops and use what we currently have.  Is there a USB to DB9 or RJ45 to DB9 that can be used for these with a Windows 7\10 laptop?  Does the switches support this?
Thanks in advance.
Photo of Phillip Hood
Phillip Hood
  • 352 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,488 Points 2k badge 2x thumb
Photo of David Coglianese
David Coglianese, Embassador
  • 7,158 Points 5k badge 2x thumb
Yes, there are several USB to serial adapter on Amazon. I prefer the $20 ones personally as I have had better luck with them.
Phillip Hood
So I don't guess the RJ45 to DB9 adapter would work with these switches?  We have some old ones that came with some old Cisco equipment that is no longer in use.
Nick Yakimenko
Those RJ45 to DB9 are for RJ45-made console ports on old cisco's
I believe those only work the other way. The RJ45 would connect to the switch.
Phillip Hood
Thanks a bunch.  Will look into getting a couple of these.
