DCB configuration with Equallogic devices
  • Problem
  • Updated 4 years ago
Getting DCB errors with equallogic devices.  I have a 6210, 6100, 6500, and 4100 equallogic units.  All the ports say DCB is off except for the 6210 they say its on but I show baseline control errors for those interfaces.  The others just state unknown for baseline.
================================================================================         Baseline DCBX TLV Status:           IEEE DCBX TLV Status:
Port     Control  PG       PFC      App      ETS-Conf ETS-Rec  PFC      App
1:7      ERROR    OK       OK       OK       OK       UNKNOWN  OK       OK
1:9      ERROR    OK       OK       OK       OK       UNKNOWN  OK       OK
1:10     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:11     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:12     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:13     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:14     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:16     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:17     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:19     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:21     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:23     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:26     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:28     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:30     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
1:32     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:1      OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:7      OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:10     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:11     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:12     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:14     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:15     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:16     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:26     OK       OK       OK       UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:28     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:29     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
2:31     UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN  UNKNOWN
This is the config on all the ports, this port is on the 6210 that seems to be working some what but has errors
* Slot-1 10 Gig Core A.1 # sh config | include 1:7
enable jumbo-frame ports 1:7
enable flow-control rx-pause qosprofile qp4 port 1:7
enable flow-control tx-pause priority 4 port 1:7
configure vlan iSCSI add ports 1:7, 1:9-17, 1:19, 1:21, 1:23, 1:25-26, 1:28-32, 2:1, 2:7, 2:9-16, 2:25-26, 2:28-32 untagged
configure qosprofile QP1 minbw 0 maxbw 90 ports 1:7
configure qosprofile QP2 minbw 0 maxbw 90 ports 1:7
configure qosprofile QP4 minbw 0 maxbw 90 ports 1:7
configure qosprofile QP5 minbw 5 maxbw 95 ports 1:7
configure qosprofile QP6 minbw 5 maxbw 95 ports 1:7
enable lldp ports 1:7
configure lldp port 1:7 advertise vendor-specific dcbx ieee
configure lldp port 1:7 advertise vendor-specific dcbx baseline
configure lldp ports 1:7 dcbx add application name iscsi priority 4
I have read the documentation from both equallogic and extreme and both are really rather vague.  Its like both just expect it to work no real troubleshooting documentation on either end.  I have also checked the best practice guide from Equallogic on configuring DCB as well.
Any help would be appreciated, thx.
Photo of Jason Weems
Jason Weems
  • 412 Points 250 badge 2x thumb
Posted 4 years ago
Jason Weems
I forgot to mention the switch model sorry
* Slot-1 10 Gig Core A.3 # sh switch
SysName:          10 Gig Core A
SysLocation:
SysContact:
System MAC:       02:04:96:97:F0:24
System Type:      X670V-48t (Stack)
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Fri Apr 10 01:02:35 2015
Timezone:         [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time:        Sun Mar 22 04:18:09 2015
Boot Count:       32
Next Reboot:      None scheduled
System UpTime:    18 days 20 hours 44 minutes 26 seconds
Slot:             Slot-1 *                     Slot-2
Current State:    MASTER                       BACKUP (In Sync)
Image Selected:   secondary                    secondary
Image Booted:     secondary                    secondary
Primary ver:      15.2.2.7                     15.2.2.7
Secondary ver:    15.3.3.5                     15.3.3.5
Config Selected:  primary.cfg
Config Booted:    Factory Default
primary.cfg       Created by ExtremeXOS version 15.3.3.5
                  1314090 bytes saved on Fri Apr 10 00:02:23 2015
(Edited)
