debug packet capture not working
  • Question
  • Updated 9 months ago
  • Answered
Just trying to run a debug packet capture on the following:
Stack of 4 x X450G2-48P-10G4, running version 22.2.1.5-patch1-4
As per the following GTAC articles:
https://gtacknowledge.extremenetworks.com/articles/How_To/Perform-a-packet-capture-in-the-EXOS-CLI-u... (This article is slightly wrong in that I had to use 'ports' not 'port' as shown.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-perform-a-local-packet-capture-on-a...
Have tried the following commands:
debug packet capture ports 1:21 on vlan B20_23-L-GND-Voice cmd-args "-c 1000"
debug packet capture ports 1:21 on count 1000
These both take OK but the only file produced in the /usr/local/tmp is a file called capture.log
When I look at that file capture.log it contains the following:
tcpdump: can't add port 10015 on packet socket: Protocol not available
Maybe there is some restriction, perhaps on a stack, model or version that is causing that issue that I've missed?
Appreciate any help in advance.
Many thanks
Photo of Martin Flammia
Martin Flammia
  • 5,744 Points 5k badge 2x thumb
Posted 9 months ago
Photo of Andrew Imam
Andrew Imam, Alum
  • 1,026 Points 1k badge 2x thumb
Hi Martin,
This appears to be related to the "CR xos0066839 : When debug packet capture is enabled for a port, pcap file is not created in internal-memory". This CR has been fixed in EXOS 22.3.1.4.
Please let us know if you have any other questions.
Thank you.
Best regards,
Andrew
Martin Flammia
Thanks Andrew - that sorted it.
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
