Decoding a SecureStack Internal Power Failure error message
  • Article
  • Updated 4 years ago
  • (Edited)
Article ID: 12464
SecureStack C3, C2, B3, B2, A2
A 'show support' or current.log (5487) reports that an internal power source is not working properly or is not present.
For example:
<162>Sep 16 11:35:11 SIM[105324496]: hwutils.c(2333) 146 %% Internal Power source is not working properly or is not present.
This message is reporting a failing internal power supply, which may or may not be backed up by a C2RPS redundant power supply (5741).
While in this state, the output of a 'show system' query should indicate a PS1-Status of other than "Ok".
The affected stack unit number is represented by the last digit of the IP address string - here, "" - which in this case indicates switch unit 3. To resolve to the physical unit, see 5780
Please contact the GTAC for assistance.
See also: 5743.
Photo of FAQ User
FAQ User, Official Rep
  • 13,590 Points 10k badge 2x thumb
Posted 4 years ago
There are no replies.
