default route questions
  • Question
  • Updated 4 years ago
Is it possible to configure static routes to manage specific networks only.  Let me explain, I want 2 specific networks to traverse my switches (one side is trust and one is untrust - METRO E circuit) and wanted to find out if I can just configure 2 static routes and don't configure a default gateway - which in my mind would eliminate the need to blackhole all remaining possible traffic since one end of this connection is untrusted.  Am I understanding this one correct?
Thank you,
Photo of Ted
Ted
  • 1,174 Points 1k badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hey Ted
Yes you can do that.  Think of the default route as one last static route.  it is there as a catch all if the switch doesn't know where to send the traffic.
If you use the correct static routes then you don't have to use any other routes.
Does that help?
Thanks
P
Photo of Ted
Ted
Yes and that's great.
Thanks for your help.
