Default TCP TTL for X450e-48p
  • Question
  • Updated 3 years ago
  • Answered
Photo of Sidney Yoder
Sidney Yoder
  • 190 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
IP TTL default for any EXOS switch is 64.
Sidney Yoder
64 what? ms or sec or min?
Patrick Voss, Alum
TTL is measured in hops. So anytime the packet is routed.
Photo of Taykin Izzet
Taykin Izzet , Employee
  • 2,944 Points 2k badge 2x thumb
Sidney, You can also perform an SNMP get against OID 1.3.6.1.2.1.4.2.0 to get the default ttl value or ping an interface on the switch.
X450e-48p.12 # show snmp get 1.3.6.1.2.1.4.2.0
mib_2.4.2.0 = 64
* X450e-48p.14 # ping 11.11.11.11
Ping(ICMP) 11.11.11.11: 4 packets, 8 data bytes, interval 1 second(s).
16 bytes from 11.11.11.11: icmp_seq=0 ttl=64 time=1.060 ms
16 bytes from 11.11.11.11: icmp_seq=1 ttl=64 time=10 ms
16 bytes from 11.11.11.11: icmp_seq=2 ttl=64 time=0.335 ms
16 bytes from 11.11.11.11: icmp_seq=3 ttl=64 time=8.085 ms
(Edited)
Sidney Yoder
reason for my questions, a consulting company that helped us migrate to dynamics 2013, is noticing that when they run a query from the server the report is generated. however when the client runs the report the hour glass just spins because the TCP connection either time-out or was closed. client - extremeSW - ospf (54ms) to our coreSW - FW which the vlan is behind the FW. The Fortigate FW's default TCP time-out is 60min. Trying to determine where it is dropped, i guess I need to fire up Wireshark.
